Connecting PAC SNI-35 lineout converter to Mono signal
akielb
I have a 2008 Honda Pilot. Replaced the factory 10" with a Polk MM1040 DVC pushed by a kicker ZX300.1. I connected the PAC SNI-35 to the front speakers off the factory HU. I have to use the Factory HU due to factory integrated RES(rear entertainment system).
I noticed that on some tracks where I know there to be some deep bass that the polk will barely produce where I swear the factory woofer made more. Other tracks that have higher bass(don't know proper term) I have a ton of bass. This makes me think that the factory HU has a cutoff for the front speakers expecting the woofer to get those frequencies. Let me know if you think my logic is flawed.
The woofer connection from the factory HU is a mono channel. Only two wires go to it. SO...my question finally is, how would I connect the PAC SNI-35 to a single set of wires. Maybe there is a simpler way to connect a mono signal to an amplifier, but as you can image searching with the words amp and mono give me great results. Any help would be appreciated.
Thanks,
akielb
akielb
FARGO, ND
keep_hope_alive
