Connecting multiple wires to battery
those are pretty awesome the way they screw in hate the plastic cover though!!!
Nothing a rattle can can't fix! For my grounds I have 4 wires though, should I just not connect the OEM wiring? I know that's frowned upon but doing so would save me a lot of thinking.
always keep the oem wiring.... put one on a lug and put that whole cover with the 3 on top of it!!!!
What do you mean? Right now the OEM wiring hooks on to a clamp terminal thing around the battery post. I'd have to cut that off, strip it back some, and then put it in the adapter. Maybe I should get a 2 0ga in, single out distro block and hook the 2 Big 3 wires into that, then I'd be down to 3 wires.
run three wires off terminal that you showed me and put a lug on one of the big three wires and bolt to the terminal? by any chance do you got side post as well?
Nope just top... Still not sure what you mean, either. I have 2 Big 3 grounds, a ground wire running to the rear batt, and OEM wiring coming in. Grand total of 3 0ga wires and what I estimate to be 2ga for the OEM.
If it were top and side post I'd have it all in by now, woulda just connected OEM wiring to the top post and all the ring terminals to the side post.
or you could just use a batt terminal and dual inputs that adapt 2 runs 0ga into one...
Like this?
Might not even need the Knu konceptz terminals then, although I do want them... They're pretty and a much better system than bolts and ring terminals. Maybe I'll use the ones I have now for my rear battery so it's not a total waste
jrdnhsnbrg
Pimped my grandma's ride
jrdnhsnbrg
Eau Claire, WI
jrdnhsnbrg
