Confussion between the Fi BTl & RE SX 12"
FX1 Series 1-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 1700 watts x 1 chan.
2 ohms: 2500 watts x 1 chan.
1 ohm: 3200 watts x 1 chan.
Max power output: 5500 watts x 1 chan.
Fully regulated PWM Power Supply
Wired remote bass level control included.
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost)
High Speed Digital Circuitry
Single channel operation
Bridging Synchronization
System distress indicator
4-Way Protection circuitry
Mono speaker output connector
Nickel Plated Heavy Duty Power & Speaker Terminals
Phase Switch 0-180
Variable low-pass filter (50-150 Hz)
Subsonic Filter (15-40 Hz)
Frequency response: 15-150 Hz
Dimensions: 17.5" L x 10.3" W x 2.4"H
FX1 Series 1-Channel Class D Car Amplifier RMS Power Rating:
Phase Switch 0-180
You will not get that much power out or it. You will need 2 of these if this is the rout you really want to go. I say go with the Sundown 3000d. If that is out of your price range I can look around for another option for you.
ronnie2359
ronnie2359
India
Rashaddd
