Confussion between the Fi BTl & RE SX 12"
He= OP. Its not for a friend, he referred to us as friends. As you can see he is from another country so there is a language barrier.
They are both grate subs. I would go with whatever one you can get cheaper. Then build a box to specs and get a amp with enough power to push it.
well thatz gr8 pal wat u think but if u suggest me anything that would help me to put some good thing in my car , thaztz gona hurt u ?
i just need a lil help from u i s there any prob
he wasn't being rude.....some just didn't realize there was a language barrier here(you being foreign to us)
if loud is what you want, get the btl. you can't go wrong with it.
edit: also make sure you build the proper enclosure and give the sub plenty of power.
I was trying to help. Both are very nice subs. Its all in the application. You can make either of the subs louder that the other depending on the enclosure and the power you have. I will recommend a set up for you.
1. Loaded BTL in 4 cubes Tuned to 35hz
1. Memphis MC1.2500
You will be happy with that for sure.
ronnie2359
ronnie2359
India
Rashaddd
