Confused
Jimmyswan
14
Fl
I want to hook up a 4ohnDVC sub to a JL 500/1. Do I hook up the voicecoils in parallel and then run 1 wire to + and - on amp,, or do I run a wire from each voicecoil to amp? The amp Manual says the connections are wired internally in parallel hence my confusion. Thanks.
It doesn't matter on the JL amps as they will run the same 500 watts @ 2-4-or 8 ohms. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
1.5 - 4ohms will have equal power.
( Since you have a Dual 4 subs - You should run your sub in Parallel ( All + together & All - together ) - Making it 2ohm @ the amp.
The only reason the amp has (2) + & (2) - is for multiple sub wiring...
* So you don't have to twist all those wires together ( you can put the wires on the left or right inputs - you'll still be getting the same power )
Jimmyswan
Jimmyswan
Fl
Jimmyswan
michigan born
    May 14, 2026
michigan born
    May 14, 2026
