Confused!!!!!!!!
yea coz it will blow my speakers....
IM FINALLY GETTING THINGS MAN THANK YOU //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and is 80watt rms from each speaker is that gonna be load ?
150 watts RMS x 1 bridged output (rear channels only) at 4 ohms (4-ohm stable in bridged mode)
does this mean if i connect 1 speaker on rear channel i will get 150 watt rms ? or 150 each on rear channels ?
and it says 600watt 2/4 channel amp ...... the rms is only 300.......
whats this //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Stated RMS is usually 1/2 max. Assuming load = loud, it won't break any records but it will be good enough. About what I was working with when I first started. Not to say that I am a pro now.
I would explain it but it's easier if you have diagrams. Search for bridging amps.
so this amp has 600 watts max PEAK POWER and 300 watts RMS power ?
and when i hook 4 4ohms speakers to this i will get 150 peak and 60 rms each ?
im sorry if im bothering u again n again
thanks
75W x 4 RMS into 2 ohms, 20Hz - 20kHz @ 0.1% THD
60W x 4 RMS into 4 ohms, 20Hz-20kHz @ 0.08% THD
60W x 2 + 150W x 1 RMS into 4 ohms, 20Hz-20kHz @ 0.1% THD
There you go. Should be fine.
i must chime in... there is no way in hell that you are going to listen to music at such high volumes that 75 watts or 60 watts is required for the speaker. i have a 50 watts running to my speakers and i dont even turn my headunit that high... other ppl have measured and say their speakers usually dont get more than 20-30 watts at high volumes.
so dont worry about getting the biggest, baddest amp in terms of power. get one that is known for quality sound and puts out SUFFICIENT power. (that means, stay away from the sony)
newdavid
newdavid
usa
newdavid
