Confused on what this switch is?
waterboy
I think i must have missed something in the ad. I was looking for a good, slightly used set of 12''s for my boat install. Went to town today and picked them up..
They are the Infinity 124.7 12" subs with a ported Memphis box. On the back of the sub where the wires plug in theres a switch that says "2" and "8" and is selectable between the two. I didnt see anything about this in the ad.
Now Im confused.. Will my 2000 watt 2 channel amp work for this? How will I hook them up? I went through the wiring diagrams on here and none of them mention this switch..
Heres the specs on the sub:
Speaker Type :passive
Speaker Diameter :12"
Nominal (RMS) Output Power: 350 Watt
Response Bandwidth: 18 - 250 Hz
Input Impedance :2/8 Ohm
Sensitivity: 90 dB
Magnet Type: Neodymium
Connectivity Technology: Wired
Additional Features: Dual voice coil
Any help?
Car Audio & Electronics got their hands on a new Infinity Kappa Series 124.7w and put it through the paces. They ended up giving it an above average score of 70.5 out of a possible 100 points.
The most promising feature on the new Infinity subwoofer is a simple switch to adjust the resistance between 2 ohms and 8 ohms (there is also a dual 2 ohm model available). I know similar things have been done before, but it is nice to see this being employed more often just for simplicity.
http://www.audiojunkies.com/blog/179/cae-reviews-the-new-infinity-kappa-series-1247w
ok, so that allows you to select the ohms, but how in the heck do i wire it up off of a 2000watt 4 channel amp and how do i set the switch?
crazy shit
http://images.caraudiomag.com/images/caep_0703_02z+infinity_kappa_series+subwoofer.jpg
and my amp specs
Maximum power output @ 2 ohms 2000 w x 1
Mono amplifier
Total channel output power: 2000 Watts
LPF (Low Pass Filter) variable
HPF (High PPass Filter) variable
Built-in protection against short circuit and high temp
Remote bass control
Titanium heatsink
waterboy
waterboy
Oklahoma
waterboy
vegang
vegang
