spencer321
Wrong.
Depth does not create more surface area. Sd will be the same regardless of cone geometry. The shape of the cone will not affect the swept volume as the shape of the cone is static throughout the motion of the subwoofer. So a deeper cone doesn't "add" anything.
Even then, the formula for cone area is not simply Pi*r^2 (using the diameter of the driver itself for "r")
Where in the hell did you hear that //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Per Vance Dickason in The Loudspeaker Design Cookbook;
Sd = (3.1416 * D^2)/4
Where D is the diameter of the cone (not diameter of the driver itself) plus one third of the surround at both ends of the measurement (though some companies use 1/2 of the surround).
You all fail.
well that is incorrect, if you measure the diameter of the cone and use that formula *which is pi R^2 unsimplified i might at*, you get the area of a FLAT circle that has the radius of the cone itself, which if you took that same driver and flattened the cone, you would have to cut one side and you would notice a BIG gap missing.
just so ya know D^2/4 IS simply R^2
the CORRECT formula for the surface area of a CONE is as follows
http://www.uwm.edu/~ericskey/TANOTES/Geometry/node15.html
and depth DOES add more surface area...your trying to tell me a circle with a 10" diameter and a cone with a 10" diameter have the same surface area? you my friend fail
