Concept or Hifonics
So with my current electrical and a better battery in the trunk should I run the Herc at 1 ohm or .5 ohm. (Electrical in Sig)
With the electrical system you have you should be fine running the herc at .5ohms, just have to becareful and watch the voltage, I ran a xx-herc the first one i owned with 1/0 gauge, and no battery in rear with factory 1991 ***** Am alt around 85amps..lol lasted for almost 1 year then finally smoked, fixed it put 140 amp alt with two yellow tops in rear and never dropped below 13.4volts at 1ohm!! You will be fine!
So I should get rid of caps and my current battery in my trunk would be fine? About what kind of power would I see at .5 ohms? And what size fuse should I use with this amp? Currently have a 150 amp in the sub amp fuse holder, but I know thats too small.
So I should get rid of caps and my current battery in my trunk would be fine? About what kind of power would I see at .5 ohms? And what size fuse should I use with this amp? Currently have a 150 amp in the sub amp fuse holder' date=' but I know thats too small.[/quote']
Depends on voltage, box rise, etc. 150 amp fuse will support it just fine.
to OP I am originally from Spartanburg and will be making a trip up there in a couple weeks, I would like to hear your setup. Were you considering the Concept because Unique Audio offers a full line of Concept and you are wanting to match sub and mid/high amps? That is the only reason I could see you considering a Concept with the Herc. The Herc will kill the Concept in output, build quality, and just being better overall. Unless it is going to be a show car I would not worry about matching amps get the Herc because it is better, It is a shame they are not produced anymore.
My current setup is in progress of being sold. I would have been glad to let you hear it, but my box subs and amp will be sold on friday. And I dont have my herc yet it will be here thursday or friday. I wont have my 4 SE's and my new box probably till a couple of weeks. O **** my bad you said you will be here in a couple of weeks. Thats cool I will PM you my phone number if you want. You can call me and we can get together. I was considering the concept 1. cause I can get it cheap 2. cause I have a 1200 on my 4 cvr 12's and its hard to breath in there so I was thinking the amp would be ok because it would double the power I already had 3. cause I could sell my concept and keep the bass knob to use with the new concept. Herc doesnt have a bass knob. 4. Could get a matching 4 channel concept for cheap.
But since the Herc is so much of a better amp it will be here friday. I will PM you my number. Later.
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Crownvicon28s
