Crownvicon28s
God 1st
Want to know what amps you guys would choose. Concept 2400 or Hifonics Hercules. Concept is 2400 watts at 1 ohm. Herc is around the same power at .5 ohm.
Really? How is that? 2400 rms is 2400 rms, isn't it? Whether you make it at 1 ohm or .5 ohm, it's still the same power with the same amperage draw to make that power.I've always had good luck with hifonics. I dont know much about concept though. Do Concept amps do rated power?
2400RMS @ 1 ohm will put a smaller strain on yer electrical than 2400 @ 0.5
hrm i may be wrong. I've always been under the impression that in order to run an amplifier at a lower load like that, you are going to need an electrical to back it. Thus, in turn, a bigger electrical system is there to keep voltage from dropping.Really? How is that? 2400 rms is 2400 rms, isn't it? Whether you make it at 1 ohm or .5 ohm, it's still the same power with the same amperage draw to make that power.
That's true. Forgot about efficiency for a second there. Yeah, efficiency does drop lower as the load drops, but on another note, I'm thinking about selling my subs to get new ones that I can wire down to .5 since most likely, box rise will take it back up over 1 ohm.Running at lower ohm loads generally tends to require more power because of efficiency factoring in. It's not guaranteed, but almost always is true. At 1 ohm for example, say 120 amps are pulled @ 14v to create 1400 rms. Drop that same amp down to .5 ohms, and set the gains to the same power with a dmm, and you'll probably be pulling an extra 10-20 amps or more.
What's funny is I forgot to answer your question. I'd buy the Hifonics. The Concept 2400's had a high failure rate, if I'm not mistaken. The revised version was the 2410, which was a bit better. I think you'll like the Hercules. I wouldn't buy the Concept just because of the known problems. The Concept should do rated but the Herc should be a bit underrated. Either way, you shouldn't be able to hear much of a difference between 400 watts.So both amps would put out about the same power at 1 ohm?
Shut up.Really? How is that? 2400 rms is 2400 rms, isn't it? Whether you make it at 1 ohm or .5 ohm, it's still the same power with the same amperage draw to make that power.
No need to disrespect man just trying to figure out what would be best ohm load to run this amp, but thanks for your opinion.Shut up.No.
Running an amp at lower resistances makes it less efficient, and thus will draw more current. Stop talking.
