Computer Experts Enter (hdd issue)
eggyhustles
Ok so my hd is failing..so i decided its time to upgrade some parts in my pc..its extremely old (compaq presario 5000t) from 2000
the specs are
Duron-900 CPU
128MB of SDRAM, 64KB L2 cache
Windows xp,
40GB hard drive
Compaq NVidia GeForce2 MX graphics card with 32MB of SDRAM,
i added 256mb of ram and plan to add another 256 to total out to 512 keep in mind that i rarely play games and this pc is only used for internet, music and videos... im gonna put in some pieces i wanted to know if they were compatible to use with this pc
will this video card work on my pc?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3001066&sku=E145-5202
can i use this power supply?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3588905&sku=VADC-803831-RTS
how is this hd?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=322750&sku=THD-80JB
will my mb support this?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1215759&sku=P511-1066
Also can you guys recommend me a cheap sound card? the intergrated sound on my pc is slowly dying..my budget is only 250...and so far with all these parts i've spent 200.77 dollars(this includes shipping)
Edit- found a soundcard, is it any good?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2177471&sku=D10-2092
Is it stupid that im pouring all this money into such a old pc? if so what do u suggest i do? saving up is not an option since i only get 200 a month and cant go without a pc
yes it is stupid to spend that much on that pc, it is worth about $50
why not build a new pc?
im on extremely small budget..too young to work legally ..i get allowance once a month for 250 so saving up for a new pc is def not a option seeing as i use it everyday i would save if the pc was still extremely usable but its on its last limb and is gonna die anyday now
the specs are
Duron-900 CPU
Windows xp,
40GB hard drive
probably, open it up and make sure the top slot is brown in color, not white, that is an agp slot. that card isnt much better than the one you have and unless you need a new card for some reason it is a waste of money
no need to switch power supplies if the old one is ok, many oem from back then are proprietary anyway
how is this hd?
any size IDE will work, look in the classies, i know i personally have an 80gb for sale much cheaper than that. keep it under 132gb partitions if you are running windows 98
yes
it will wo0rk as long as you have enough pci slots after adding the card above
Well your PC probably does not have a AGP slot or a ATA drive setup and I have no clue why you are looking to upgrade your PS??!?!?!
That said the USB card should work.. Your parent won't help you out and get you a new PC even a cheapo dell with monitor an be had for a little over $400 PC's don't last forever you know.
You get 250 god **** dollars a month as an allowance?!?!?
Aren't you a spoiled mother ****er....
maybe his parents are the type to give him a larger allowance, but HE has to buy everything he needs like clothes, food, etc
my parents were the $10 week type, but paid for everything
don't go and upgrade to any of that stuff. What you need to do is go and buy a dell or something since you don't use it for anything heavy. Find someone who has a small business and get a dell vostro through them.
agreed, i would ask your parents if they would spring for a new dell.
they can get it on a payment plan for about $20-25 month and you could either pay them or they could take it from your allowance.
anything under a 1ghz P3 or AMD Athlon is pretty much useless these days for anything but slow web browsing
Check your local craigslist and you can find a single 1.8 for a hundred probably. All you need a is a new box bro you got moniter. Check local listings, peopel give away computers better than that all the time, you just goota go pick it up ussually.
i never got allowance when i was a kid. yalls bastards man. after i got my first job and my very first pay check i went nuts. after then I'm more care full with my money and i cherish everything i own that has been bought with my earned money.
eggyhustles
eggyhustles
Bronx, NY
DejaWiz
