computer driver help
dvrmstrng
i have a IBM thinkpad t42, just did a fresh install of vista....
everythings working well except when i use volume controls and fn keys, i get no on screen display of whats happening....also i cannot view my LCD through component or s-video which i was able to do before this install...which driver should i be looking for
Is that the vista version that came with your thinkpad? Vista is not going to have all your drivers on it. I am going to guess that you had something else on there and you dsecided to put vista your computer instead... Well unless you have the device drivers disk or the original backup disk for that comp you will have some trouble. You could try to connect to the internet and to to IBM and do a driver download and system check. Sounds like a headache. I have been there before.
yes i looked...any have installed a lot of them to no avail....IBM used to have a program that would go through my computer download and install all the drivers i needed, called thinkvantage update...but discontinued it for some reason.
I do not think i have the original disk....hmmm
they are not drivers....they are programs...you should have gotten a disk with your computer that has all these on it...all your stuff is working..just not working the way you are used too....IBM might have these little plugins for download on their site but most likely you will need a disk..
i have never needed a disk to fix these types of problems,only research //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
dvrmstrng
dvrmstrng
DE
sound_around
