comps whining with idle
budahbuddy803
When ever i turn the volume to the desired 50/62 the tweeters pick up some type of whine that will fluctuate with the rpm's. If i remove the cd and put it back in it will be fine until i turn it to about 45 or 50. If i mess with the RCA's i can get it to go away but then it all just starts again. What should i do? I think it is because the RCA inputs on the amp but i dont know what i could do with them. Messing with the RCA inputs as in twisting pushing, and or pulling will get the whine to quit until some vibrations from the sub.
but that not what it is because i have 1ga split into 4ga and 8ga grounds with a non-fused distro block so if that were the case dont you think that the sub amp would have a similar problem?
who ever said that your amplifier ground was the only ground in your stereo? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
im not trying to insult you here, but if you plan on making a hobby out of this, you might want to start absorbing a little more //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
1500 posts and you still cant identify a bad ground //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
in nearly two years you still havent learned the most basic, most common problem in car stereos...
LOL!
budahbuddy803
budahbuddy803
Aiken, SC
tru_44
