grizzly 660
Ok so im a little new at all this audio stuff ad need some help from you people who know what your talking about. Ok first off, my goal is to have a complete audio system in my 2007 chevy impala within the next month. What i know or think i need....
- Amp (idk how many amps i need, what do you think?)
- Capacitor (again idk, all i know it depends on the amp)
- wiring (what size?)
- deck (Was thinking of getting this used, "Sony Xplod CDX-GT320") for 50$
- Box for subs (10" dual box, or how to make my own)
I currently own 2 10 inch "Volfenhag zx-4710 dvx" subs(Specs are pasted below from internet.)
ZX 4710DVX Specifications:
Magnet: 160 oz. Double stacked Ferrite magnets
Frame: 5 spoke Die-cast aluminum basket
Cone: Reinforced aluminum curvilinear
Surround: Oversized buytl rubber
Spider: 2 Flat ultra excursion
Power handling: 400 watts RMS, 800 Watts Program (conservative)
T Yoke: Industrial Chromed Hex bolt retained, Bumped and Vented
Double damper magnetic motor assembly
Cooling: Double Vented (T Yoke and Motor Side vents)
Voice Coils: 4 Layer Dual 4 Ohm High Temperature black Aluminum
Voice Coil Diameter: 2.2"
Nominal impedance: 4 ohms / per coil
DC resistance (Re): 3.2 ohms each coil
Frequency range: 20 Hz-1.1 kHz
Fs:32 Hz
QTS:.461
QES:.541
QMS:7.62
VAS:35L
SD:.0346M
SPL:89 dB 1W/1m
Xmax:16mm
Mounting Depth: 145 MM
Mounting Hole Dia.:246 MM
Net weight: 21lbs
I am looking to spend around 150 dollars for stuff, so if you have any thoughts on products i can always look them up on craigslist(please no ebay) or paste links. thank you for reading and how you have some valuable info for me! i will be checking this forum numerous times every day! hope to hear from anybody that has advice!! thanx
Fs:32 Hz
QTS:.461
QES:.541
QMS:7.62
VAS:35L
SD:.0346M
SPL:89 dB 1W/1m
Xmax:16mm
Net weight: 21lbs
