Common , easy question I'm sure. Wiring recommendations for setup.
Chromatic
I have a fairly good idea of what to get,.. but just thought maybe some of you had links to good deals, or complete packages for self installs.
Here is what I will be installing in a 350z.
Doors/Front Speaker/Stage = CDT CL-61-CV 6.5" Mids with the .75" Tweeters going in the Window Sail panels (Both are factory size, and will replace factory speakers directly.) -- The high mounted tweeters should bring up the sound stage well. Speakers are 100 Watts RMS a piece. $180
Cl-61cv - CDT Audio 6.5" Convertible Coaxial Component Speaker System | WoofersEtc
Head Unit = Pioneer AVH-P4100DVD AVH-P4100DVD - In-Dash Double-DIN DVD Multimedia AV Receiver with 7" Widescreen Display | Pioneer Electronics USA (Already installed).
Sub box = Custom Built box that fits exactly in the Factory slot where the Factory sub would go.
$100
Nissan 350z Vehicle Specific Sub Enclosure 1-10"
Sub = JL Audio 10w0 (75-300 Watts RMS) JL's "optimal" range on their website is around 220-250 watts RMS. $110
The alternative here is an 8 Inch Sub.
This brings back the 8 or 10" argument. Money is going to be $100-$130 on sub regardless of which size. So if that budget on sub helps you give me a reason to go with one size over the other.. please do.
JL Audio 10W0v3-4 W0v3 Series 10" 4-ohm subwoofer at Crutchfield.com
Amp: CT Sounds - 4 Channel, 125watt RMS x 2 (for 100watt fronts).. and 380watts RMS (Bridged and stable at 4 ohms) for Sub. $225
Ct Sounds 125 4 Amp Amplifier 125W RMS 250W Max Class A B 4 Channel 2 Ohm | eBay
Given I have Headunit already -- that is all.
Anything special I should be running from the back of the headunit being what it is? RCA's? Or some sort of NON speaker wire cables?
Single inline fuse all one needs,.. or a fuse block?
Thanks
Chromatic
Chromatic
B'ham, AL
Chromatic
