Comment's wanted: what box to go with?
if the amp is 1kw at 4 ohm do it sealed so the sub can handle the power if its 800 or less at 4 ohm do it ported
unless of course you know how to gain match then just do it ported //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
SUB-
# Technical Specification
# RMS Power Range : 600 Watts
# Peak Power Handling: 1200 Watts
# Impedance: Single 4 Ohm
# Diameter: 15 Inch
# Fs (free-air resonance, Hz) 28.7
# Vas (equivalent compliance, cu. ft.) 3.207
# Qts (total driver Q) 0.73
# Sensitivity 85.9dB
# Pe (continuous power handling, watts) 500
# Peak power handling (music, watts) 1000
# Mounting hole diameter (inches) 13.85
# Mounting depth (inches *) 7.5
AMP-
Features
* Maximum power output of 380 watts per channel at 4 ohms.
* Maximum power output of 1000 watts bridged mono at 4 ohms.
* Built in Low Pass filter 80 Hz 18db per octave.
* Hi level sensing power on feature allows unit to be activated without need for remote trigger.
* Pulse power supply.
* Frequency response 5 Hz to 50 kHz.
* Total harmonic distortion .008% at 1 kHz 4 ohm.
* Dimensions: 16 3/8" x 2 1/4" 11 3/8"
# SPECIFICATIONS
* Amplifier Class : N/A
* Number of Channels : 2-Channels
* Maximum Power : 1000 Watts
* RMS Power Output @ 4 Ohms : 185 Watts x 2-Channels
* RMS Power Output @ 2 Ohms : 200 Watts x 2-Channels
* Bridged Power : 1000 Watts @ 4-Ohms
* THD (Total Harmonic Distortion) : 0.008%
* Signal-to-Noise Ratio (dB) : N/A
* Frequency Response (Hz) : 5Hz~50kHz
* Built-in Crossover : Active Crossover
* High-Pass Crossover Frequency : N/A
* Low-Pass Crossover Frequency : 80Hz
* Bass Boost : N/A
* Bass Remote : N/A
* Fan Cooled : N/A
* Fuse Rating : 30A x 2
* Dimensions (Width x Height x Length) Inches : 16 3/8" x 2 1/4" 11 3/8"
* Approximate Weight : 9.6 LBS
byrdman75
byrdman75
Troy, MO
byrdman75
