coils?
  • 2
chevy808
Hi
Does having dual coils make a difference?? Is it better to have dual or single. I'm thinking about buying the 10k, I have a JBL 600.1, the rms for the 10k is about 325rms, if I am not mistaken. Should I buy the single coil 4 ohm and give the sub 300 watts or should I buy the dual 4 ohm and run it in paralell? Would 600 watts be too much?
Wiring options, my friend.
With a SVC 4ohm K series, you would be able to wire your sub like this:
With a DVC 4ohm K series, you would be able to wire your sub like this:
or
DVC will give you more flexibility when it comes to wiring. Also a good choice if you plan on purchasing an additional K series driver down the line.
Would I send 600 watts to a K? Probably not...it doesnt need that much - it is a very efficient driver. Hope that helps.
- Steve
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
959
Deff be a disaster and quite a shame blowing a freshly repaired amplifier in a few min.LOL. Id be very upset for sure. id recommend the wiring...
23
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
chevy808
chevy808
Hi
ss3079
