chrisw91
how much better quality and sound will i get out of components compared to the 6x9's in my sig?
that all just went way over my head! can you elaborate? say i get components, the woofer will be in the door, where in the door panel should the tweeter be?If coherency is of any value to you, a coaxial driver will always have the advantage of being as close to a point source without actually being one. The only improvement would be a single full range driver but that poses a new set of advantages/disadvantages.
The center of the tweeter should never be any further from the center of the woofer by more than a full wavelength at the crossover frequency. For example, if the crossover point is 3k that amounts to about 4.5". Depending on the particular rate of attenuation per octave you will have phase/lobing issues to deal with if you decide to make that distance greater.
Something to consider.
Well, I won't tell you where to put everything but let me be more clear about what I was trying to illustrate.that all just went way over my head! can you elaborate? say i get components, the woofer will be in the door, where in the door panel should the tweeter be?
