clipping amplifier
  • 4
slickrick
19
Texas
My question to everybody is if a messed up car battery, or a lack of power from the alternator cause an amplifier to start clipping? Or is this only caused by the gain adjustment and maybe even giving an amp to low of an ohm rating, and messed up wiring.. Also what about the grounding of the wire could that play a factor.
I have a rockford fosgate BD1000 amp that is clipping just a little bit. I have checked the wiring and everything is correct. It should be showing the amp a 4ohm load. Would a capacitor help this problem. The manual to the amp says it can handle down to 2ohms.
Does anybody know why it might be clipping?
Thanks for any advice or recommendations.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
721
Don't recall off hand. Both single dins. One excelon, one not.
932
1. make sure you wired your subs right... https://jlaudio.zendesk.com/hc/en-us/articles/204374200-Dual-Voice-Coil-DVC-Wiring-Tutorial 2. set...
10
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
6K
I would pull the HU and bench test it. Can be done with a 12v battery on a non-metal work bench easily enough.
16
slickrick
slickrick
Texas
MikeofTulsa
    May 18, 2024
    May 18, 2024
