clipping amplifier
slickrick
My question to everybody is if a messed up car battery, or a lack of power from the alternator cause an amplifier to start clipping? Or is this only caused by the gain adjustment and maybe even giving an amp to low of an ohm rating, and messed up wiring.. Also what about the grounding of the wire could that play a factor.
I have a rockford fosgate BD1000 amp that is clipping just a little bit. I have checked the wiring and everything is correct. It should be showing the amp a 4ohm load. Would a capacitor help this problem. The manual to the amp says it can handle down to 2ohms.
Does anybody know why it might be clipping?
Thanks for any advice or recommendations.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
slickrick
slickrick
Texas
MikeofTulsa
michigan born
    May 14, 2026
michigan born
    May 14, 2026
