SOLD Clearing out what is left, insane deal on DLS A3 & ID XS65 COMPONENT SET! LOOK!
desertheat
Tempe, Az
DLSA3 out of my show car, MINT condition in original box and packaging. $275 SHIPPED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Just need it gone!!!!!!!!!!!!!!!!!!!!!!!!
XS65 FULL COMPONENT SET IN ORIGINAL PACKAGING! 8 HOURS TOTAL USE IN MY SHOW CAR! $275 SHIPPED!!! Set runs $499 from ID.
I accept paypal and my prices are FIRM. Can ship tommorow !
Pm for info.
Here are some pics //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
how efficient is the A3 ? I have been looking to trade off my pdx 1.1000 would you be interested I have the iridium components in my car this might make a good match.
Sorry guys no trades, and it is a pure class a/b twin mono design. No class D so it is power hungry. It is designed as a purist front stage amp, not a bass amp, although it can produce the power.
Specs are as follows...
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz
Mode : AB
Number of channels : 2
Output power in 4 ohm : 2 x 150 watt
Output power in 2 ohm : 2 x 270 Watt
Output power in 1 ohm : 2 x 425 Watt
Output power in 4 ohm bridge mode : 550 Watt
Output power in 2 ohm bridge mode : 870 Watt
Output power in 1 ohm bridge mode : 1200 watt
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filter, highpass, variable : 20 - 200 Hz
Filter lowpass, variable : 50-125 Hz
Terminal for external cooling fan : Yes
Double DC-inputs : Yes
Phase shift button : Yes
Current draw, idle : 1,1 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight : 6,2 kg ( 13,67 lb)
Sorry guy was waiting on a seller that planned to buy 1 item today / and his friend take the amp in a few days as they were ahead of you. If I do not hear anything by midnight or get payment firmed up, you are next in line.
Some of it plays well, some not so well lol. New decaf going around of "Break the knob off!" I have been playing and like it.
Sounds like you shorted the other channel so check you connections. Don't ask just look. Will solve your problem Every time. If you ever short out...
desertheat
desertheat
Tempe, Az
desertheat
    May 12, 2024
Brendon Jenness
    May 11, 2024
