Sold Clearing out what is left, insane deal on DLS A3 & ID XS65 COMPONENT SET! LOOK!
desertheat
DLSA3 out of my show car, MINT condition in original box and packaging. $275 SHIPPED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Just need it gone!!!!!!!!!!!!!!!!!!!!!!!!
XS65 FULL COMPONENT SET IN ORIGINAL PACKAGING! 8 HOURS TOTAL USE IN MY SHOW CAR! $275 SHIPPED!!! Set runs $499 from ID.
I accept paypal and my prices are FIRM. Can ship tommorow !
Pm for info.
Here are some pics //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sorry guys no trades, and it is a pure class a/b twin mono design. No class D so it is power hungry. It is designed as a purist front stage amp, not a bass amp, although it can produce the power.
Specs are as follows...
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz
Mode : AB
Number of channels : 2
Output power in 4 ohm : 2 x 150 watt
Output power in 2 ohm : 2 x 270 Watt
Output power in 1 ohm : 2 x 425 Watt
Output power in 4 ohm bridge mode : 550 Watt
Output power in 2 ohm bridge mode : 870 Watt
Output power in 1 ohm bridge mode : 1200 watt
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filter, highpass, variable : 20 - 200 Hz
Filter lowpass, variable : 50-125 Hz
Terminal for external cooling fan : Yes
Double DC-inputs : Yes
Phase shift button : Yes
Current draw, idle : 1,1 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight : 6,2 kg ( 13,67 lb)
Sorry guy was waiting on a seller that planned to buy 1 item today / and his friend take the amp in a few days as they were ahead of you. If I do not hear anything by midnight or get payment firmed up, you are next in line.
desertheat
desertheat
Tempe, Az
desertheat
