classic mint Alpine v12 4 channel & 2 channel F407 & 757
  • 6
gentlejax
Item(s) for Sale:f407 & 757 v12
407
+/-30V rails
16400uF rail capacitance
Channels 3/4 can be bandpassed with built in crossover (50Hz-8Khz adjustable).
404 Not Found
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20kHz)
MRV-F407 (CH-1 – CH-4)
Per channel into 4 ohms ........................... 40W, 0.08% THD
Per channel into 2 ohms ............................ 50W, 0.3% THD
Bridged into 4 ohms ................................ 100W, 0.3% THD
Power Output: RMS Continuous Power (at 14.4V, 20 Hz to 20KHz)
Per channel into 4 ohms ........................... 60W, 0.08% THD
Per channel into 2 ohms ............................ 80W, 0.3% THD
Bridged into 4 ohms ................................ 160W, 0.3% THD
Max. Power (at 14.4V)
Per channel into 4 ohms ............................................ 120W
Bridged into 4 ohms .................................................. 320W
Frequency Response ................... 10 Hz to 50 kHz (+0, –1 dB)
Signal-to-Noise Ratio
(referenced to rated power) ........................................ 105 dBA
Slew factor .................................................. ...... Greater than 5
Damping factor
MRV-F407 ................................................ Greater than 100
Input Sensitivity (for rated power
output) ........................ 200mV to 4.0V (1.0V at center detent)
Input Impedance ....................................... Line in: 10k ohms<
Speaker Impedance ............................... 4 or 2 ohms (Stereo),
4 ohms (Bridged)
Active Dividing Network Frequency and Slope
MRV-F407 ............. 50 Hz to 400 Hz x 20, 12 dB per octave
Power Requirement .................. 11 – 16V DC Negative Ground
Dimensions (W x H x D)
MRV-F407 ............................... 260mm x 60mm x 330mm
(10-3/16" x 2-3/8" x 13")
Weight
MRV-F407 ........................................ 5.3 kg (11 lbs. 10 oz)
757
Output Power at 12.0V (20Hz 20kHz):
2 x 75W @ 4 ohms (0.04% THD)...............actually does 2x115@12volts UNDERATED!
2 x 150W @ 2 ohms (0.3% THD)
1 x 300W @ 4 ohms Bridged (0.3% THD)
Output Power at 14.4V (20Hz 20kHz):
2 x 100W @ 4 ohms (0.04% THD)
2 x 200W @ 2 ohms
Item(s) Description/Condition:I am 2nd owner of the 757 . it is complete and super mint. nice nice amp. I just have decided they are too big for where they need to go. the 757 is still in box.
the 407 is in my trunk right now .
Price:$200 plus shipping
plenty more pics here:
Login to a private Photobucket.com album
757
407
I havnt heard the 757 yet. I am tempted to hold on to it but I am trying to run all class D .
I think the price is really fair considering the shape. The 757 is a 1 owner amp till me.
Ok thanks, i suspect that this one i uave may be faulty. I will purchase another one for the sake of it and see, thanks
371
Well, generally speaking, I would agree. But that is like saying that PRV, Stetsom and Taramps are all the same. Similar maybe, but not the same...
It is an L port. You might as well add three 45's. Add one by the leg of the L and the two that I showed you in my other post.
Thank you both :) I'll probably wait it out for the SA-12 v.2s in that case. Always learning on this forum and I appreciate it so much as always!
It was also 1960 and the quality of sound you could get out of the loudspeakers of the day was going to be rather anemic even given optimum...
gentlejax
gentlejax
Bossier City, La.
gentlejax
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
