Class A/B vs. Class D power for Subs
I would say there isn't really an audible benefit. Class d's are more efficient which when you are running a high wattage substage, is important because your electrical system will have less strain
well, i dont think its anything audible, but your electrical system will love you for running class d with the subs. unless of course youre running lower wattages like 400-600.
class D efficiency at full capacity - 75%
class A/B efficiency at full capacity - 60%
class D efficiency at 1/3 capacity - 70%
class A/B efficiency at 1/3 capacity - 35%
Class D amps will have a higher distortion point at max capacity.
Class A/B amps will have a lower distortion point but a lower efficiency also.
Most class D amps include seetings geared for subs. IE - lower LPF/HPF settings. Subsonic filters.
And on most class A/B amps, the frequency range on the HPF/LPF is much higher.
class D efficiency at full capacity - 75%class A/B efficiency at full capacity - 60%
ok thanks:D
96GTIVR6
96GTIVR6
Oregon
thch
