Class A, B, C, D
  • 4
its the way they amplify to put it simple. a is the best sounding but is the least effecient a/b is the most popular sounds good but is more effecient than class a by about 20-30 % class d is noisey but produces its power with digital switching thus its 20-30% more efficent than a/b amps.
The class definitions come from the way the circuits are "biased". It has to do with how much power the circuit uses when no signal is present, and therefore efficiency.
Class A draws 50% power with no signal, so it can only be 50% effiecient best case. The upside is it has the absolute lowest distortion.
Class B has a theoretical effieciency of 78%. But has lots of distortion. Used only in portable voice amps (like bullhorns) where battery life is more important than sound quality.
Class AB is somewhere in between. It's the most popular configuration. They run maybe 70% efficient (not including their internal power supply) and can have very low distortion.
Class D uses digital switching technology instead of analog circuits. The signal is chopped up into narrow pulses and fed into switching transistors that are either on or off. Then it's fed back through a lowpass filter to "reconstruct" the signal. They have excellent effieciency at the expense of having zero high frequency response and somewhat higher distortion. Perfect for sub amps.
Class T is a new technology where I believe they modulate the power supply instead of the output stage (not sure about that). Supposedly gives high effieciency without the dawbacks of Class D. They cost bucks tho.
they can make class d full range it sounds like class b...class t is full range although i never "heard" one on just mids and highs still subs...hmmmm
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
  • Locked
Hello and great day to all of caraudio.com family . So I'm here looking to see if anyone may know of someone wanting to sell there steg msk 50sc...
Ok , to answer your question about the counterfeits yes , so sinfoni sold rights or lost the rights to a chinese company a few years back and so...
Have an Xli 2500 as a sub amp in the music room, overkill for sure, never overheats, never skips a beat.
150
10K
budgetSQ
Basshead
budgetSQ
CT
audiolife
