Sold Clarion DXZ785USB
c_nitty
Item(s) for Sale:Clarion DXZ785USB
Item(s) Description/Condition:Got new used for 7 months in a second car but in mint condition General Features:
In-dash CD, MP3, WMA player with Remote
iPod USB direct connectivity via your standard iPod-to-USB connection cable allows you to charge, control, and playback your iPod through the receiver and stereo system
Motorized, detachable face
Green dot-matrix display
Wireless remote control included
Green button lighting
CEA-2006 compliant amplifier
Power Output:
Peak: 53 watts x 4 channels
RMS: 18 watts x 4 channels
CD Text Display
MP3 ID3 Tag Display (Title/Artist/Album)
Playback and Audio Features:
Playback of CD, CD-R, CD-RW, MP3, and WMA
Tuner with 18FM/6AM presets
EQ3 (3-band parametric equalizer with seven preset tone curves)
Digital Z-Enhancer allows you to choose from 9 custom EQ Curves
Features built-in 2-Way and 3-Way crossover settings
Expandability Options:
3 Sets of 6V preamp outputs (front, rear and subwoofer)
SIRIUS Satellite Radio Ready: A subscription is required for service as well as the Clarion Sirius Satellite Radio Package or Clarion XM Satellite Radio Package
Bluetooth Ready: Clarion BLT370 Bluetooth module required and sold separately
iPod Ready *: Clarion EA1276B iPod adapter recommended and sold separately
The Apple iPhone 3G, iPod Nano 4th Gen, iPod Touch 2nd Gen, and any other newly released iPods can be controlled using the iPod adapter above; however, charging will not be possible unless you purchase the Scosche IFWA PassPORT charging adapter.
Rear auxiliary input: USB Port and 3.5mm (headphone jack) allows connection to portable media storage and devices such as MP3 players, etc.
RCA Auxiliary input with level control
CD Changer controls
Key Features:
2-Line display with screen savers
Optional OEM Steering wheel remote ready
Built-in IR Eye
Subwoofer volume control
CeNET bus
Slidetrak control provides easy-to-read displays, increase button size, and control of the key features on the head unit
Allows for the built-in amplifier to be turned off if an aftermarket amp is installed
Message up to 30 characters can be stored into the memory of the head unit and be displayed as a screen saver
Price: $156 shipped Paypal only
If you run your system actively or ever wanted to, this unit will allow you to. It features a 3-way active crossover with digital time alignment and parametric EQ. Its really a pretty substantial DSP for a modest price tag. It also features 24 bit D/A converters and the ability to bypass the internal amp for use with out-board amplifiers. It has 3 Sets of 6V RCA pre-outs. I have checked that the preouts put out just under 6 volts a little under max volume.The crossover allows support for traditional front/rear/sub setups but also the capability of full 3-way active (Front highs, Front lows, Sub-woofer). When in active mode you have full control over the filter frequencies and a choice of 6/12/18dB per octave filtering. Phase can also be switched on the fly. The parametric EQ, while only 3 bands, offers lots of adjustability. There are countless frequencies where you can set the bands to, and an adjustable Q and level for EACH SIDE. Essentially you have an individual 3-band EQ for the right and left sides. Another point of interest is the 728 variable coloring for the illumination of buttons/screen. With so much versatility you can easily match the color of your car's dash illumination or you can make it whatever you want or cycle through colors if you prefer something a little flashier.The USB implementation is done well on this, it allows a maximum of 256 songs per folder in 256 folders... Which equals a total of 65,536 songs it can access through USB. I was using a 320GB hard-drive hooked up through USB and it worked great.
c_nitty
c_nitty
Houston,Tx 77044
c_nitty
michigan born
    May 14, 2026
michigan born
    May 14, 2026
