Clarion Drx6575z wiring diagram HELP
Ok I got everything wired perfectly but I have 3 left over wires
Solid blue
Blue w/ white stripe
Yellow with a fuse
But I already hooked up a yellow with a fuse a thicker solid yellow.....
Thanks in advance guys.... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Solid blue
Yellow with a fuse
Solid Blue is the power antenna lead
Blue w/ White Stripe is amplifier turn on lead
Yellow with 3 amp fuse is the "Bus Power" lead (12v constant same as the other yellow wire)
I think on my older clarion drx9575rz both yellows are hooked up at the same place. One of the blues should be your amp turn on and the other should be for like power antenna or something like that, not sure which is which though, I will try to find my old manual and see what it says.
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
