Clarion amp?
Scoobydoo
POOPSIE McSQUIRTYSHORTS
I have owned numerous Clarion Pro Audio decks and I really like them, but I have never owned a Clarion amplifier. I have owned JL, Soundstream, PPI, Orion and A/D/S amps and was wondering how the Clarions compare with them SQ wise?
The amp will be powering a set of A/D/S 236is 6.5" components. I would love to get another A/D/S to power them, but my budget is too low and they are extrememly hard to find anyway.
100 watts x 4 would be optimal, but again budget doesnt permit spending more than about $100 on an amp right now
The Clarion model I am looking at is the APX4240:
Features
MOSFET power supply
Built-in variable low-pass or high-pass crossovers
50-300 Hz crossover frequency
Line or speaker level inputs
2 ohms stereo/4 ohms mono stable
Gold-plated input and output terminals
GLIIC (Ground Loop Isolation Input Circuit) for noise rejection
Bass Extender 0, 6, 12 dB boost control at 50 Hz
CEA-2006 compliant specifications
Multi-Channel Amp Specifications
Amplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 60W x 4 @ 14.4V
THD at 4-Ohm RMS Power:
Bridged RMS Power @ 4 Ohms: 180W x 2 @ 14.4V
Speaker Level Inputs: yes
Preamp Outputs: no
Built-In Crossovers: HP/LP
Bass Boost: 0, 6, 12 dB
Frequency Response: 20-30,000 Hz
Signal to Noise Ratio: >85 dB
Dimensions: 13 L x 10 7/8 W x 2 3/4 H
Basically it comes down to whether or not this amp be able to make my A/D/S speakers shine like they should?
clarion is just like entery level... pioneer, sony,and jbl...they are ok nothing....nothing....compared to ads...but they are just fine for running high's
ok thanks for the replies, i figured they probably werent the greatest amps, but i wanted to match my deck in a way and at $105 shipped it seemed like a good choice
i am going to be running these through the a/d/s crossover so hopefully the final impedance is 4 ohms, the manual doesnt say
how about the 2 channel aura 2300?
that would give me about 75 watts per speaker and still fit my $100 budget:)
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=269-162
Here's something that will suit your budget and leave you with enough for a value meal, a pack of smokes , and $10 in gas besides! Factory-direct refurb, valid 1 yr warranty, 150w X 2 @ 4 Ohms.
Look here and scroll to the CA600. $65 + shipping (however much that would be...can't see it being more than $15 so you've only spent $80)
Scoobydoo
Scoobydoo
DINGLEBERRY
Prowler573
