The 10 10s? Or the 9515?Just put it in a big ported box. It should get louder than that sealed clamshell design.
I don't want to do a wall. Also, I know 2 12s can do 150 burps easily. But I want to keep the amp I have. I clamped my Stetsom at 2500 rms at 2.4 ohm. So I have a good bit of power, but that 2.4 is risen up from 0.5 nominal. Therefore, when I start dividing up the power between woofers, it gets less and less. There aren't too many pairs of 12" subs that can get up into the 150s with 1200 - 1500 rms a piece in an SUV. But they are available. However, they are not cheap. The best option would be the HDC3, but even they are over $400 shipped, and I don't think there are any more in stock.the best resource is simply trying new things out yourself. to start, a wall is not needed to do 150. 2 12's and will can fairly easily do 150 on a burp
That was the original plan before this idea. However, it is proving more difficult than I thought it would be. To get louder, I figured I would use external aero ports and a smaller box. However, I don't just want a fart box, I want something that will play music for daily driving as well. So I decided to go with around 3.75 cubes net, and use a pair of 6" aero ports. But in order to tune to 38 hz, each port has to be 24" long! My longest max dimension in the back of the Rodeo is 40 inches. 40" - 24" = 16". On top of that, the port opening is supposed to be approximately as far away from a surface as it is wide. 16 - 6 = not enough surface area left for me to mount a 15" sub. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gifKeep what you have and make it louder...those woofers are worthless. Installed MANY of them in various cars at the shop I used to work at. With what you have you should be able to accomplish that goal...and only spend 20 bucks on a sheet of MDF.
You should do a box with interchangeable ports one tuned high to the frequency of you cabin for SPL and one for daily.I don't disagree. But I just can't seem to get this Rodeo loud. I currently have it in 4.25 cubes tuned to 39 hz with around 100 sq in of port. Sub facing rear, port facing rear. I plan to keep this set up for the regular year.
However, I also contemplated a different box. 3.75 cubes net tuned to 38 hertz with 64 sq in of port, sub up, port back. But I don't know if it would any louder.
those ****.You should do a box with interchangeable ports one tuned high to the frequency of you cabin for SPL and one for daily.
