Chrysler 300 Dimming fix. *for now*
  • 1
znewberry
Illinois
Just thought ide share my recent experience. I plan on upgrading asap. I have a build log going if you want to check it out. However this video will demonstrate how the same system that caused HORRIBLE dimming. I mean flashing hard on bass hits. was quickly solved for now.
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
Big 3 will not help dimming. Big 3 helps get more power to your amp, which is the opposite of what you want to reduce dimming. Either add lifepo4...
581
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
znewberry
znewberry
Illinois
znewberry
    May 18, 2024
    May 18, 2024
