click ->
http://search.cardomain.com/cgi-bin/MsmGo.exe?grab_id=35&EXTRA_ARG=&CFGNAME=MssFind%2Ecfg&host_id=42&page_id=333568&query=tantrum&hiword=tantrum+
says this
Designed with an emphasis on earth shattering power and exceptional sound quality through advanced engineering and efficient production technologies, the new Tantrum series amplifiers from Phoenix Gold push the envelope in competition-grade car audio. With highly efficient, Tri-Path Class T operation, the 1200.1 handles the demands of a high performance mobile audio system with maximum power and dependability. For superior sound reproduction, the Tantrum 1200.1 features an internal, continuously variable 18dB per octave crossover for greater versatility. This series also offers an adjustable Twin "T" bass EQ circuitry that slams in your face bass. The new thermally efficient heatsink design supplies improved thermal dissipation and is designed to be joined with additional Tantrum amps for a clean looking multi-amp install. Optional LPL wired Low Pass Level control and RMD Remote Monitoring Display.
Please note that Phoenix Gold amplifiers and speakers are only shipped to destinations within USA.
Every Tantrum Series amplifier exceeds published power ratings and comes with its own spec sheet.
Features:
High Efficiency (over 70%) Class T Circuitry
Thermally Efficient Heatsink
Timed Acoustically Integrated Muting (TAIM)
Differential RCA Level Inputs
Preamp Outputs
18dB / Octave Low-Pass Crossover
30Hz to 300Hz Continuously Variable Crossover Frequency
18dB / Octave Subsonic Filter
Variable Twin-"T" Bass EQ Circuit Provides Up to 18 dB of Boost at 45 Hz
Optional RMD Remote Monitoring Display Port
Optional LPL Low Pass Level Controller Allows for Driver's Seat Adjustment of Bass Volume
2-Ohm Stable
Subwoofer Mono Amp Specifications
Amplifier Type: Mono
RMS Power: 1200W x 1 @ 4 Ohms
Bridged RMS Power: 1400W x 1 @ 2 Ohms
THD at Rated RMS Power: n/a
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Channel Separation: n/a
Signal to Noise Ratio: >95 dB
Fuse Rating: 80 amps
