Reply to thread
Car Audio Discussion
cheepest 4channel amp?
Message
<blockquote data-quote="indosia" data-source="post: 382981" data-attributes="member: 543175"><p><a href="http://mailto:" target="_blank">endosia@comcast.net</a></p><p></p><p>Specs are as follows:</p><p></p><p>1400 watts RMS x 1 @ 2 ohm</p><p></p><p>700 watts RMS x 1 @ 4 ohm</p><p></p><p>High Efficiency Tri-Path Operation</p><p></p><p>18dB HP/LP Continuously Variable Crossover (30-300Hz)</p><p></p><p>18dB Continuously Variable Subsonic Filter (5-50Hz)</p><p></p><p>Low Pass Level (LPL) Control</p><p></p><p>Twin "T" Bass EQ Circuitry</p><p></p><p>Load Stability 2 Ohm Mono</p><p></p><p>Dimensions with Endcaps: 19.25" Length x 10" Width x 2.35" Height</p><p></p><p>Dimensions without Endcaps: 14.25" Length x 10" Width x 2.35" Height</p></blockquote><p></p>
[QUOTE="indosia, post: 382981, member: 543175"] [URL="mailto:"]endosia@comcast.net[/URL] Specs are as follows: 1400 watts RMS x 1 @ 2 ohm 700 watts RMS x 1 @ 4 ohm High Efficiency Tri-Path Operation 18dB HP/LP Continuously Variable Crossover (30-300Hz) 18dB Continuously Variable Subsonic Filter (5-50Hz) Low Pass Level (LPL) Control Twin "T" Bass EQ Circuitry Load Stability 2 Ohm Mono Dimensions with Endcaps: 19.25" Length x 10" Width x 2.35" Height Dimensions without Endcaps: 14.25" Length x 10" Width x 2.35" Height [/QUOTE]
Insert quotes…
Verification
Post reply
