check this crazy ish out man.
bass-aholic
Alright i bought a design for $5 which is the first one you see and then i designed the second one. Which one is better and also since its my first real box build i might use the second one with aeros because it would be a lot simpler to build. Can you verify i did everything right on the second one? Its for 2 18" q's. 11.6 cubes gross, about 10 net. 4 4" aeros 8.13 inches long for 35 hertz(should i use 4 6 inch aeros, i have seen really good results with 4 6 inch aeros?) Thanks a lot to everyone who helps.
Design number 1, blocked out numbers so because i don't have permission to post the designers work.
My design, should be easier. I already have all the wood and supplies.
i agree the port wouldnt be that hard but it is harder than aeros plus i like the look of aeros. does anyone know if four 4" aeros would be enough port area or if i should use 6" if i decide on that design.
and dont mind my spelling/grammar im on a cell phone
bass-aholic
bass-aholic
New York
15nissen
ThxOne
    May 13, 2026
