check this box
perfecxionX
this is the first ported enclosure ive ever designed and built myself. can someone check my calculations and give any advice on the design?
it should be about 4.1@33
Looks good...but where you show the port's length ending, it should be approx another half of the ports width past that because the wall of the port is also the back wall and it keeps extending outward, acting like the port still...
looks like big moofers
may I suggest double baffles and some support beams?
I got 4.3 without sub displacement so I'm assuming you're correct about the 4.1 cubic feet. The tuning is closer to 31hz though as your effective port length is around 33.5".
The effective port length will be the length of the line down the center in this picture:
And in case you didn't know, you can get the surface area of complex shapes using sketchup.
And like the others, I recommend putting in some bracing in there to strengthen the enclosure.
perfecxionX
perfecxionX
indianapolis
Immacomputer
