75MonteCarlo
pwned by the R
Ok here's my idea.. we know that spl is the pressure level created in a car's cabin right, so we need a way to move more air, in order to get more pressure. We know that 2 12" subs are going to move a certain ammount of air, based on the level of exursion and force with which they move. Here's my thought, what about using the pressure created by a pair of 12's to move a much larger plate, which would in turn move a much greater ammount of air on its own? In my design, I thought of using a large acrylic window mounted to a rubber surround on one end of a sealed enclosure.. the subs would create pressure inside the enclosure, and the pressure would force the window to move back and forth with the subs. However, the window would have a lot more surface area, and therefore should be able to move more air and increase our SPL level.. BUT i've thought of some problems with this idea:
1.) Air acts like a spring, so the window is not going to move with as much force as the subs do.
2.) The window will not get as much excursion as the subs, because the window has a greater surface area than the subs.
3.) The rubber surround may actually cause the window to absorb energy instead of increase the spl level.
Here's a pic of my idea, tell me what you guys think.. could this, would this, work?//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
