blackgeltabs
Knowledge is Power
This is a post stricktly for me to refer people too, no one needs to reply its pretty much for my own use.
This is to be used for your trunk lid only, it will cost about 8 bucks and you will see a phenominal difference.
Basic cheap trunk rattleing solution:
1 can of triple Expanding Foam
1 can of Spray on Under coating
1 tube of caulking
Start by caulking the seams of the trunk lid bracing under the lid, let this dry for awhile 4 hours is usually good.
Next spray the cavities of the bracking with triple expanding foam. DO NOT COVER SPOTS WHERE YOU WILL NEED TO CHANGE BULBS WITH FOAM. That will make for a horrible time cutting the foam out. Let foam sit for 4 hours or so.
Caution- You will want to line the bottom of your trunk with garbage bags or some plastic sheets. The triple expanding foam will leak out of some some spots, and its a B to get cleaned off of the upolstry or even the paint.
Last spray the whole trunk lid with undercoating spray.
Once this is all done then sound deadening mat will only improve deadening more, but this is a good base to have under SD mat. This alone will give your trunk lid a nice hollow thump when you knock on it.
Here are some pictures to help you out with.
1 tube of caulking
