Cheap HU distortion....
jgarcia9102
Ive got a cheaper HU, its one of the lowew model JVC's, and i know its not great but for now its what i have to work with.
Now, everything is great at lower volumes, but when i crank it up i get distortion. Now i know its because its a cheap HU, but im wondering if there is anything i can do to minimise it
Right now im just running front stage off the HU. The volume is good till about 29/50, then up to 33 its only noticible in certain songs, then after that its pretty noticible all around.
What im wondering is if i use an external amp for my front stage, which i am planning to do in the next month, would it reduce the clipping? Or is it all in my HU, and even the Pre outs will be just as distorted?
I dont expect the distortion to go away, im just wondering if using the pre-outs will reduce it at all...
An external amp would greatly reduce the level of distortion you're hearing and vastly improve the dynamic range...there's really no substitute for it as you'll soon hear //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Nope, just some Type S coaxials untill after christmass when i can afford some Comps.
Thats why ill be getting the amp in the first place, to power the comps. But i would first put money into a new HU if it was absolutely necessary, but it looks like i can manage for a while without it.
thanks for such quick responses guys.
Properly amp them, and deaden your doors with a layer or two of sound deadening. These two things will do so much to improve your front stage...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Right now there is some dynamat on the doors, but not much. ill add some more when i do the Comps.
Im actually trying to re do my system the right way this time. I bought the car with a pretty crappy attempt of a system in it, and ive been trying to fix it up.
recently i decided im just going to re do the whole thing since thats the only way ill know its done correctly. Meaning more dynamat, Front stage amps, and possibly a new HU
Jack, is there anything you dont know?
jgarcia9102
jgarcia9102
Rochester NY
jgarcia9102
