Cheap DD Replicas
Everyone look at SkatinBassPlaya's profile, under interests...he lists "watersports"
A quick visit to UrbanDictionary will reveal that "watersports" means:
sensual or erotic play involving bodily fluids, typically urine, saliva, and less commonly, blood. Considered 'edge-play', because it is obviously somewhat unhygenic.
You sir, have quite a little bit of time under your belt, it seems.
You ARE trying to be/be like an over-tanned, worn out, Slim Jim eating wrestler..
Maybe you should compare your two situations? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Originally Posted by evilbeaver
Ok here's my measurements, without any break in.
--- BassBox Version 2.00, Export Thiele-Small Format
--- Oct 12,2007, Fri 6:26PM
--- Click here to change driver name
--- Parameters marked with ** are not tested using the WT2
--- mechanical ---
Fs 49.344E+00 Hz Free air resonance
Qms 12.636E+00 Q mechanical
Vas 24.913E-03 m^3 Suspension compliance
Cms 25.846E-06 m/N 1/(suspension stiffness)
Mms 402.502E-03 kg Moving mass
Rms 9.876E+00 kg/s Mechanical resistance
Xmax ** 0.000E+00 m Maximum acoustic linear motion
Xmech** 0.000E+00 m Mechanical displacement
Dia 323.850E-03 m Piston diameter
Sd 82.372E-03 m^2 Piston area
Vd ** 0.000E+00 m^3 Displacement volume
--- electrical ---
Qes 522.806E-03 Q electrical
Re 1.887E+00 ohms Voice coil DC resistance
Le 2.959E-03 Henries Inductance @1 kHz
Z 25.817E+00 ohms Impedance @1 kHz
BL 21.220E+00 Tm Motor force - Newtons/Amp
Pe ** 0.000E+00 W Max Electrical Power
--- electro-mechanical ---
Qts 502.034E-03 Q total
no 537.947E-03 % 1/2-space ref efficiency @ 1m/1W
1-W SPL 89.325E+00 dB sensitivity at 1m on-axis
2.83V SPL 95.600E+00 dB sensitivity at 1m on-axis
--- motor constants ---
Krm 23.666E-03 ohms constant resistive motor impedance
Erm 677.732E-03 exponent resistive motor impedance
Kxm 135.280E-03 Henries constant reactive motor impedance
Exm 559.435E-03 exponent reactive motor impedance
--- End BassBox Export ---
I have more then time under my belt //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Silly boy.
Yeah, the beers took me over last night. I should have put that down as a disclaimer so folks could ignore me. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Apologies to DJL - nothing personal man, please don't take what I said seriously.
I pretty much respect everyone's point of view, since folks have tested/used products that I have not. So if someone says brand X is better than brand Y, who am I to argue?
The surround stitching thing is real tho. Someone mentioned that another brand had stitching on some 80's models. This would make sense, especially if the cone was poly. We ran into surround issues with the old Energy 22 woofers when they first rolled out - we couldn't find a suitable glue that would hold the poly cone to the rubber surround. Sewing it was the only option.
Nowadays, adhesives have come far and this is no longer an issue (that I'm aware of), other than what I stated. Of course there is the aesthetic value to having a cone that is stitched, if done up properly, it could look quite appealing. Other than that, it is for the most part unnecessary.
So, now you know the background of my post. Just thought I would try to share some of my (old) experiences with you.
Best regards,
Mark
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
Cameron_B
