Sold Cheap Amps ($150-$200 range)
8000x
The ONLY reason I'm selling these is because I need a bigger 4 channel. If Pioneer made one in this series then I would be keeping these amps! Pioneer created these to compete with the legendary Alpine 35xx series amps. These are the cleanest, most accurate, most detailed amps I've ever heard next to my old McIntosh.
Very classy looking amps too, they have a unique blue phosphorescent illuminated logo when powered on. I have two 2 channel amps and one 4 channel amp. The 4 channel is 65 x 4 at 4 ohms, 75 x 4 at 2 ohms, and 150 x 2 bridged at 4 ohms. Specs for the 2 channel amps are below. Check out the specs, they pretty much speak for themselves.
$200 shipped for the 4 channel and $150 shipped for each 2 channel.
Continuous Power
2 ch: (4 Ohm) 100Wx2
2 ch: (2 Ohm) 150Wx2
1 ch: (4 Ohm) 300Wx1
Frequency Response: 10Hz - 65kHz (0,-1dB)
Total Harmonic Distortion: 0.003% (1kHz, 4 Ohm)
Signal-to-Noise Ratio: 107dB (IHF-A Weighted, at 1kHz)
Dimensions: 10" x 2-3/8" x 12-3/8"
Features
Bridgeable 1/2/3 Channel Capability
1-Ohm Stable Operation
Class A Circuitry
PWM Regulated MOSFET Power Supply
Balanced Isolator Input Circuit
Gold-Plated Screw-Type Power/Ground Terminals
Gold-Plated Screw-Type Speaker Terminals
Gold-Plated RCA Inputs
Gold-Plated RCA Outputs (Pass-Thru)
Top-Mount Controls
Variable Crossover: 50-120Hz, -12dB/oct. (LPF)
Bass Boost (60Hz, 0 to +12dB)
Hi-Volt Input Level Control (400mV-6.5V)
Dual-Fan Cooling
Illuminated Logo
Here's some pics
Some shots in the dark
8000x
8000x
usa
8000x
