Cheap amp for Cadence CWM6 Components?
Pickler
Just looking for a nice amp to power them and definitely something cheap (the comps are only 75 shipped so just recommend me something.
CWM-6K
6.5" 2-WAY COMPONENT KIT
6.5" 4 Ohm Woofer
1" Ferro Fluid Cooled Silk Soft Dome Tweeter
1.25" High Temperature Voice Coil
RMS Power: 100
Peak Power: 200
Frequency Response: 65Hz-22KHz
Sensitivity: 93db @ 1W/1M
Mounting Depth: 3"
Butyl Rubber Surround
High Strength Alloy Cone
Stamped Steel Basket
Alloy Bullet Phase Plug
External Impedance Matching Zobel Crossover
14K Gauge Gold Plated Terminals
Flush and Surface Tweeter Mounts
1 Year Warranty
I'd second that or even the 1502 if you're thin which would give you 75X2. If I were in your shoes I'd get the 3002 and have some headroom to spare if you're looking for 2 channels.
These are great amps for the price and they do rated power. I was hesitant, but have been pleasantly surprised with mine.
Cadence FXA-6020 $60 shipped fron Cadence Direct on the Bay....With warranty. 60x2@ 4 ohms. I am running one on my old Soundstream Exact 60wrms comps in my Beater S10 and it gets them way loud enough.
60x2 is not even close to enough
I might just go with the 150x2 amp then.
Can any one else also recommend a cheap amp install kit?
Check out KnuKonceptz. You could probably get away w/the 8 gauge if this amp is all you plan on running. If you even remotely think you're going to get a substage I'd go w/the 4 or even 1 gauge depending on how big you want to go. Wire's expensive, so better to do it right the first time and not have to mess w/it again.
if you want a slightly better quality, go with the zrs line. I was going to go with the txa 3004, but then decided eh, ill move up to the txa 6004. If woofersetc wasnt out of stock Id have that and not the zrs 9004. The numbers are very comparable, but its a cleaner power. The daytona is their best and there arent many differences, but the daytona's efficency is much better!
I have a four-channel Kenwood that makes 100w X 2 @ 4 Ohms when bridged that I could let go cheaper than you've seen anything else going for thus far.
If interested PM me for further details. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well thanks for the input guys, and I will look into the amps you guys are selling.
So this amp kit would be enough to run any of these amps I do get?
Complete 4 Gauge 4 Channel Amplifier Installation Kit
Item #: KOL-AK44
more than plenty //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif best to go as thick as you can afford. you can get away with 8, but 4 would be better
I've got a crossfire vr404. Nice amps. You can pick them up on ebay for like $100. I'd get one of those again before one of those cadence txa's. Just personal preference, though.
I don't really have a need for 4 channels though, just need 2
and I will probably get that amp kit then, just deciding on an amp.
It's bridgeable;) You can run it on 2 channels just like a 2-channel amp. In fact, that's what I do.
Pickler
Pickler
Las Vegas
Pickler
