changing tuning from 33hz to 38hz
i would make ur port 24^2 (2x12) 1.5" is small and might create some port noise with those subs.. It would also work with your new tuning .. On a 1.6^3 per side you could do a 2x12 port 23.5" long
What is the box volume? The volume will determine what length you want you ports. The bigger the port the better ie 4" is better than 3" because you wont get as much 'mach' (port noise), but the bigger the port the longer it has to be. Let me know I can figure it for you. It is best to keep the ports on the same plane as the sub-how much depth do you have from the front-back of the box?
l7 s are nice tunedhi, there not sq so y try to tune it to be , u'll be happy with 38 hz.. Considering 35 is avg... 33 for square 10s??? no thanks thats where a w7 would sound grat , not l7s
With 2 10s with 3 inches of port width will not make any port noise, u get below 1.5 ur askin for trouble
yeah i've been looking for a W7, but i have been unsuccessful. box volume is 2.9cu ft. its from the plans in the sticky--->http://img29.imageshack.us/my.php?im...z36sqin5xd.png. so what should i tune it to then for a good balance betweeen LOUD and DEEP too. i just want to see what they sound like in a ported box compared to .75^3 ft sealed per sub. oh yea if it matters they are powered by kx1200.1
If were talking about ur L7s tune anywhere from 35-40 , for a good daily setup , that will play low and clean.. 35 -38 is just fine prolly 38 since there10's imo...
kpozr2
kpozr2
Iowa CIty, IA
hzsogood
