changing blown mosfets.....
BassAddictJ
how hard is it....can you simply find out the exact kind you need, order it online, and sodder into place? if one or 2 are blown should you replace them all???? id rather give it a shot myself then blow 100+ at a repair shop....
If you don't mind ruining the amplifier, I would try it. If it works, then you have experience, if it does not, then oh well, you know what went wrong.
ohming? whats that mean... and what is the correct ohmage for a diode and a capacitor? if your going to try and sound smart please use real words
You need a DMM with at least a diode setting so u can check the mosfets that u cant tell if they are blown
also you need a o scope to make sure the amp is putting out clean waves after you fix it... bottom line dont try this on your new 20.1, but if u have a old pyle amp thats blown that would be good practice
When I was fixing a Blown rockford amp that I had, I noticed a small surface mount transistor that was bad and I had to replace that also. Just some advice that more may be wrong than just a FET that's burnt.
its an mtx 150d.......and after all these advice AND talking to mtx and local repair shops...im gonna buy a new set (22 to be exact) mosfets and pay a local shop to put them in and fix anything else wrong...its a very reputable shop so im not oo worried...$35 to look at the amp, which is subtracted from parts and labor in the end.....and if i supply the parts the labor shoudlnt be too bad with $35 knocked off....they said it ussually run $50-$75 for labor....minus $35......yes professionals this time around....
BassAddictJ
BassAddictJ
FL
BassAddictJ
BP1Fanatic
BP1Fanatic
