GSG2Teg
I have a Alpine CDE-HD149BT, 2 Alpine MRV-F340 Amplifiers (55w RMS x 4 @ 4 Ohms, 130w x 2 @ 4 ohms(bridged)), 2 6.5" 3-way Pioneers (50w RMS, 300w max) for the fronts, 2 6.5" 2-way Pioneers (40w RMS, 250 max) for the rears, and a set of 1" Alpine Type-R component tweeters in the rear that are left overs from a previous install . I'm rearranging my setup and it so happened to occur to me that I have some extra ports on my amplifier to bridge. I was thinking of having one MRV-F340 for the front two pioneers, and having the other MRV-F340 powering the tweeters and the set of 2-ways in the rear.
If I am short on watts I've always bridged to try and match the speaker RMS. However, I've never actually bridged and had ample space to work with. I was thinking about bridging the two front speakers to have 130w x 2 instead of the 55w, definitely hitting the RMS point(50w), but since I'll be running my rears at the 55w range (which is still hitting the RMS for those (40w)) would this be any significant difference in quality or should I run both sets at 55w to kind of keep both sets of speakers matched? Which in that case I could bridge the tweeters to run 130w RMS. I am not using the 6.5" Type-R components main drivers any more since they blew a while ago, but I am still using the filter/separator device they came with. I just forgot what those are rated at.
Or if you guys have any other suggestions on design, feel free.
