changable tuning.. port questions
abrhino
Big White King Kong
im shooting for a Tunable port for my DC LV5.. i need help with my design.. its gonna be sub up/ port back around 3.2 after wood/port/bracing displacement
External
36w X 14t X 17d
Internal
34.5w X 12.5t X 15.5d = 3.87cuft minus .68cuft port disp = 3.19cuft
Im going to divide the port into 2 horizontal sections using sanded and rounded .75MDF. directly in half so the port height will be 11.75H or 2 5.87h X 6w sections.. port displacement is .68cuft
If my calculations are right tuning will change if i plug the bottom port..
Unplugged
11.75h X 6w X 17.3L = 45hz
Plugged
5.87h X 6w X 17.3L = 33-34Hz
Will the 35.3sqin of port work for daily on the DC LV5? unplugged it is 70.6 SQin of port
what if i change the port
5.87t X 7w X 21L = 33hz and 41sqin port. nearly 14sqin port per cuft.
port displacement is 1cuft 3.87-1= 2.87cuft
or
5.87t X 8w X 24.3L = 33hz and 46.4sqin port. 18.2 sqin port per cuft
port disp is 1.32. 3.87-1.32 = 2.55cuft
Did you actually calculate the tuning using 2 ports or did you just calculate it for one then plan on dividing the port? Because you can't just divide a port and keep the same length, it will affect the tuning. Also, for when the one is plugged, did you take into account the fact that one of your ports is now part of the net volume? That also will affect the tuning.
I think this is more complicated than you think...interchangeable ports would be better.
yes, i accounted the port displacement into both of my designs.. the one with 7in port width is 2.87 cuft after port displacement.. and YES i calculated both ports in the12volt port calculator..
in a 36w X 14t x 17d box it is 3.87cuft before port displacement
port (account for .75 brace/separator) 11.75t X 7w X 21L = 45hz
half the port height (bc its plugged) 5.88t X 7w X 21L = 33hz
thats what my calculations came up with. Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
That's not what I'm talking about. All your calculations for when you have both ports open say that the port is 11.75H, which it's not, you have two ports that equal 11.75H. You can't just take a port and divide the height in half, it will affect the tuning. And I know for a fact you didn't do this because the12volt calculators don't allow you to enter that you have more than one port.
you're right. thanks
Use the carstereo.com calc, you can enter as many ports as you'd like. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
will do man, thank you
why is the12volt and carstereo.com port calculators so far off? I pluged in my current box on the12v and it it was 3hz off of carstereo's calculations
current box
is 4.99cuft before port displacement.. port is 14.5h X 5.5w x 16.75d which equals 40hz on Carstereo and 43hz on 12v
abrhino
Big White King Kong
abrhino
middle TN
basshedz06
