Cerwin Vega V-Max 102 dual 2 ohms practically new
cleansoundzz
Bought new, used for 10 minutes and has been sitting since.
V-MAX series subwoofers, like the VMAX102, has been the most popular, award-winning, series of Cerwin-Vega subwoofers for the last 10 years for many reasons. The series of subwoofers are offered in a 10", 12", and 15" size with each respective size having the option of a Dual 2 ohm or Dual 4 ohm voice coil. They offer a power rating of 1000 watts peak and 500 watts of continuous RMS power making them your daily "ground-pounders". With these many different sizes and impedance options, these woofers offer versatility and a significant amount of bass that is sure to fit anyone's bass needs. The woofers feature a composite polypropylene cone and a wider larger than normal rubber surround for increased excursion level, performance, quality, and strength. The use of O2 Cast technology increases basket strength and lowers basket resonance, which also increases the quality and performance of the subwoofers. The woofers also feature cross-flow window venting that reduces voice coil temperatures and radial contact convex domes that reduce cone flex and minimize distortion. If you want to achieve exceptional low-frequency reproduction that is accompanied by quality manufacturing and amazing value, look no further than the Cerwin-Vega VMAX series subwoofers.
  • 10" Dual 2 Ohm VMAX Series Subwoofer
  • Power Handling:
  • Peak: 1000 watts
  • RMS: 500 watts
  • Impedance: Dual 2 ohm
  • Polypropylene composite cone woofer for the perfect weight to strength ratio
  • Wide rubber surround
  • Radial contact convex domes design minimizes cone flex and reduces distortion
  • Window framed venting draws cool air directly to the voice coil for increased power handling
  • Dual linear rolled spiders for unmatched assembly cone control at all volumes
  • 2.5" Dual 2 ohm high-grade voice coils
  • O2 Cast technology increases basket strength while lowering basket resonance for increased performance and quality
  • Sensitivity: 83.1 dB
  • Cutout Dimensions: 9-1/4"
  • Mounting Depth: 6-3/8"
  • 1-year Manufacture's warranty
$90 shipped anywhere in the US. No trades.
cleansoundzz
cleansoundzz
Buena Park
cleansoundzz
