center box port question displacement
OLD_SCHOOL
i have a port that needs to be 2x24x13.5 however i want that port to be in the middle of the box insted of the side
porth height is the same as the box height can i just run a 13.5 inch port down the middle move over 2 inches and then run a brace say like 15 inches and if so i would only need to figure the normal port side wall config displacemnt plus that brace (with endcorection) right ?
is this ok to do ?
Mat
like this where the short line to the left is the 13.5 inch port wall and the longer line to the right is brace that is like 15 inches giving the box a port tube 2x13.5 only in the center not sure if this will work
no not realy i was just looking at something a little differant
turns out it won't work anyway because i figured the port area wrong i was still using 3.5 cubes per box insted of eight cubes total one enclousre porth lenth almost tripled heheh
best to do just two chambers port each if you want it in the middle i reckon
OLD_SCHOOL
OLD_SCHOOL
Buford, Ga. Metro ATL
supa_c
