Here are the specs and some info from the CDT Audio web site:
Model:
CL-641
4"/6.5"
3-way Midrange/Midbass 4" & 6.5"
Mounting depth 2 1/8" / 2 7/8"
Crossover "Phase Perfect" Elliptic 4th order 3-way SatNet/SubNet-642
Tweeter 3/4" Silk Dome
Power handling 190 watt RMS
HighPass 100Hz
Frequency response 55-20kH
Sensitivity 92.4 dB.
Impedance 4 Ohm
Surface & Flush mount tweeter
Peak Power Handling 175 Watts
If you want European world-class smooth natural sound and design, CDT's Classic CL-641- 3-way component set is the speaker for you! It borrows* much technology from its bigger brother, the HD642, an award winner in many world wide comparison test's, at a new lower price point.
2 - 6.5" midbass drivers, featuring our compound curvature, carbon treated cones for "Contoured Dispersion." Stainless steel top and bottom plate for heat dissipation. Gold plated terminals. Real butyl rubber surrounds and flat spiders for linear cone excursion. 12 oz. magnets. 2 - 4" midrange drivers, with the same quality features as the 6.5." 2 - 1" silk soft dome swiveling tweeters, featuring neodymium magnets and Ferro fluid cooling for power handling and a silky smooth top end. 4 piece Subnet/Satnet crossover network. Featuring our exclusive 60 dB. "Phase Perfect" design for the deepest, widest and most stable stereo image and soundstage ever. Polyswitch protection for long tweeter life and 3 step adjustable tweeter output.
CDT designs and builds its drivers and crossovers to the very highest of standards. Years of experience and design flexibility yield higher quality and better performance. Quite simply, we produce "audiophile" sound, smoother response, wider dynamic range, and better imaging and sound staging. Our incredible midbass and midrange drivers are flat to 6 kHz! That's 6 octaves response! This puts much less stress on the tweeter, providing better power handling and much better sound. Our special "Contoured Dispersion" radiation pattern in the critical midrange frequencies delivers rock solid imaging and front staging, with virtually no side biasing. These carbon treated cones are smooth and natural sounding thanks to an ideal combination of stiffness and damping. The compound curvature shape prevents cone flex and break-up. This provides clean midbass, even at higher levels. The critical midrange frequencies are clear and precise with no distortion from "ringing." The mids use a real butyl rubber surround, not merely a mixed butyl compound.
The silk soft dome tweeters use an incredibly powerful neodymium magnet and ferro fluid cooling for high power handling. The treble these tweeters provide is wonderfully smooth and distortion free with excellent off-axis response and virtually no dynamic compression.
The 4 piece "phase perfect" 60 dB. crossovers use military grade connectors for long life and perfect transfer of the electrical signal. These connectors can handle 600 volts and 30 amps! All crossover parts are low loss Mylar caps, iron core inductors and use large signal land paths. Summary: The soundstage this complete system produces is amazing! Its beautifully defined left to right and front to back and has the feeling of emanating from free space rather than "typical car stereo locations." The stage is deep, wide and stable, like you've never heard before. Last but not least, the super steep 60 dB. roll off will provide extended tweeter life and higher power handling because of dramatically reduced low frequency demands on the tweeter itself. "This is why we say, Let The Music Begin!"
These are great speakers! CDT Audio is a highly acclaimed though little knwon company. Though they have an excellent product, they have purposely kept their company small. I opened the box to check the speakers but never installed them because I can't fit them comfortably in my car. They will definately make their new owner happy.
$200 + shipping takes them.
Model:
CL-641
4"/6.5"
HighPass 100Hz
Impedance 4 Ohm
