CDA-9831, no sound but HU is playing music
daktruckie99
10
MA
Got a little problem here and don't know what the actual culprit is.
Just put the CDA-9831 in 3 weeks ago and have had the problem 3 times since then, once a week it seems.
When I turn the car on the stereo comes on and displays the track counter as if the unit is playing the song but no sound comes out. The only way I have been able to get music to come back on is doing a full reset by hitting the button on the faceplate. The problem effects both CD and radio.
I really don't like doing the reset however because then I need to redo all my time correction and EQ settings not to mention all the radio presets.
I have toggled the internal amp on and off but this has no effect. I am running the HU straight to my amp via RCA's then from the amp to the speakers. However it did this prior to the amp going in so I am pretty sure it's not the amp.
Anybody seen this problem before and/or have a solution for me?
Thanks in advance.
-Mike
Your EQ settings will not be reset.
Did you try to turn on defeat and turn it back off when "it" happens? I use to have the same problem when I had that deck. I still do with my deck but not very often, maybe once a month of so.
Well I just went into the car and it was doing 'it' again. Turned defeat on and then back off and voila, music!
Thanks for your help.
-Mike
-Mike
Nice to hear it works! My 9815 had a similar problem, but unfortunately switching things around didn't do anything //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif when it would do it the motor for the cd insertion stopped as well. When I first read your symptoms, I thought maybe the same had happened...nice to see it didn't!!! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
daktruckie99
daktruckie99
MA
Abneriel
