CD7000's ipod control
  • 2
I've got that setup now. It works great IMO...definately not full speed, but after coming from the 7800 pioneer with it's interface, i've noticed this is much faster. You can navigate through the menu's just fine, and it doesn't loose your location in the menu when you get out of it and return like the annoying pio ipod interface did. All in all, it works great with some playlists or the random function used.
I would turn it to either flat, or better yet off if you have that option and use the head unit to control the eq.
I had to go from the headphone jack to an rca converter and plug into the back of my head unit. My old iPod won’t directly connect on any of my...
919
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
This is in a 2015 F150 regular stereo and I'm using the front speakers for a signal. The EQX is hooked up speaker level. I put a cheezy line...
Puggsley456
Who said you could talk?
Puggsley456
WPG>MB>CAN
Abell255
RedRyder18
    May 11, 2024
RedRyder18
    May 11, 2024
