CCA vs OFC
CCA vs OFC
  • CCA
    Votes: 5 20.8%
  • OFC
    Votes: 11 45.8%
  • Audio wire
    Votes: 0 0.0%
  • Welding wire
    Votes: 8 33.3%
  • Total voters
    24
i have 2 runs now of power and ground ,and adding another one soon,all ofc. even the big 3.i actually had 8 runs of power and 6 of grounds at one time ,then down sized to 2 runs of each.buy every time i added runs ,my db's went up
I run CCA. I have a buddy who swapped all of his shok 1/0 cca out of his burp CRX for shok OFC and he didn't gain anything on the TL. It's dialed in to do the same number constantly.
But it is install dependent for sure.
From the front battery to the rear battery or amp. Your grounding strap in normally under the front battery, its the best ground in the car
What about the front battery to the engine block. ANd the back batteries to the frame?
Is it still better to run from the front battery to the trunk?
I need to know because as soon as it gets nice out. (winter ends) I am going to remove my seats and stuff to do these extra runs. And I only want to have to do that 1 time
frt to block and back to frame is good ,but mine ar still grounded to each other with 2 runs frt to back
So right now. I have 1 to the engine block. 1 to the trunk/frame. I have an another available spot on the opposite side of the trunk for another spot.
And should I do 2 runs of ground from the front battery to the back ones?
you can if you want.if you look at any competition vehicles ,they have the same amount of runs frt to back of each
How come?
THis is just a daily driver though. But I obviously want to do things right so every lasts and nothing breaks.
jockhater2
jockhater2
Saukville, WI
jockhater2
